24 views not a clue!!!
I need to programme ABS Module after replacing from scrappy I need Login and Software code, I have provided rear boot label photo.
Engine Labels No: 03G- Lads 906-016-BKC.1b1
ABS Module No: TRW440C2ESP
ABS Labels No: 3C0-614-095-C2.c1b
Any thing else info you need please let me know.
Thanks in advance
l take it you cant read old one anymore ? if you have original vcds rosstech can help
try this http://www.netech.dk/vagecue.html
super jumbe (24th February, 2017)
VW/Audi is very confusing..I can never understand why need to login to change coding or to program something.
On VCDS Ross-tech website all info is if you have the Bosch ABS unit, this one is TRW Unit I have never come across before, as you said I will have to replace the old unit and see if I can get the login pass, I thing I have come to the dead end.
