Page 108 of 219 FirstFirst ... 85898103104105106107108109110111112113118158208 ... LastLast
Results 1,606 to 1,620 of 3273
  1. #1606
    Newmotors's Avatar
    May 2019
    brazil
    hi brother
  2. #1607
    Jan 2020
    Thumbs up
    Hi, can you tune this
  3. #1608
    Jun 2009
    UK
    Quote Originally Posted by IceSan View Post
    I suggest you not to be lazy to include information about what EXACTLY you are attaching here.
  4. #1609
    Dec 2017
    Default EGR Off SSangyong Kyron Auto
    Here you are Brother. EGR off for Automatic transmission only. Ended up doing myself with the help of some friendly Russians. The EGR should be disconnected and blocked off. The reprogramming tricks the ECU into thinking the EGR is fully open all the time. The smell of exhaust is reduced, a constant command is sent to the gearbox to lock the torque converter, Torque is available immediately on takeoff. Better fuel economy
  5. #1610
    Jan 2020
    romania
    hi , need help delphi dcm3.2 mercedes w204 220cdi 170hp ....original file pls!!!
  6. #1611
    Jun 2013
    Quote Originally Posted by Vicentiu2020 View Post
    Flash vediamo
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
  7. #1612
    Jan 2020
    romania
    Apr 2018
    HI i need EGR-DPF off mercedes c220 cdi w209 150hp
    ECU 0281012725 A6461505091 damp 1037376896
  9. #1614
    Jan 2020
    Hi I need popcorn limiter at 4000 rpm
    EDC17CP02
  10. #1615
    Oct 2018
    Europe
    Default Bmw 525
    Please stage 1 and remove dpf
  11. #1616
    Nov 2018
    Europe
    Hi , i need help , OFF heater oxygens sensor 2 , switch off . Skoda Octavia 1.6 SIMOS3.3 5WP44232_CAS33043_7290 . 1u , BFQ
  12. #1617
    hello,
    i need decat file for this.. golf 1.4tsi 1037522350 - 9660
    thank you
  13. #1618
    Aug 2019
    Default Hello, I need to successfully disable delphi egr
    Thank you for your help
  14. #1619
    Oct 2019
    Italia
    Default Help
    Help dpf egr off fiat panda 1.3 8df
  15. #1620
    Jun 2019
    Default golf mk5 1.9tdi
    stage 1 please
