friends, could someone remove the speed limiter for me? SW and HW are in the attached photo.
Hi Guys!
please help me with more power on my Passat 2.0 CRTDI
ORIGINAL 140 hp, 320 nm -- Stage 1 >>>>> 180hp – 410nm
Model year 2009
Model 2.0 TDI, manual 6 gang
ECU Information
Use type CBAB
Producer Bosch
Build EDC17CP14
ECU-Nr. Prod. 03L906022BL
Software 1037397866
Kess v2.
Thanks!
I need a stage 1 for my E46 330Ci with 231hp.
Thank you very much!
please i need edc17cp14 santa fe 2015 dpf - egr off
can make somebody stage 1 for iveco daily 2.8 bosch ms 6.3 ?
Here is Stage 1 Pass is in your PM
Eight bytes walk into a bar. The bartender asks, “Can I get you anything?”
“Yes,” reply the bytes. “Make us a double.”
asdfx (12th November, 2020)
can you work on Cummins Ecm for Dogde rams 6.7 interested in Dtc off and others map pid I/O I have some stock files available
Who can help make Euro2, disable the catalyst polling and errors of the second lambda probe? Mazda CX7 2.3Turbo 260LS (manual transmission) 2007 year. Firmware read KESS will need to recalculate CS.
hi please egr off and if possible remove maf. Make a maf on the map,
Sprinter 2004 2.7cdi usa edc16u31 mpps
I have a fault 2011 maf range. Egr is the new wahler Thanks
[QUOTE = Baddog84; 3996497] и на английском ?? [/ QUOTE]
Translated into English. Look please
[QUOTE = Maximus03; 3996513] [QUOTE = Baddog84; 3996497] и на английском ??
I've solved my problem already.
Magicmotorsport Flex Full, Magpro2, Swiftec, Winols, full ETL, Carprog and others....
anyone able to help with a full BDM read on this?
here's the ID
HW:
SW: 1037386701
VIN nr.: W0L0ZCF6881064494
SW ver.:
Spare:
Engine:
HW Ver.:
SW upg.: P485_O27
Installation:
thankyou to anyone able to help
