Hello my friend, I need some more HP for my boxer 2003 EDC15 2.0 HDI.
thank you
thank you
Can you "kill" the immobiliser in this ECU?
r 420.rar
Post in Immo Section for Quicker Result ok
spauds (21st April, 2017)
Hello m8s, is it possible to remove P0411 (VAG 16795) from this ECU? I need it to show readiness "passed" not "not supported".
Thank You!
Best Regards, Roth.
Does anyone have a tuned file for Mercedes ml55 amg? I have a 430 ecu so I don't have original. Thank you
Sent from my SM-G930R4 using Tapatalk
Hi. i need turn off egr and mil light and checksum if possible
VW Golf IV 1.4 petrol ME 7.5x
16785
P0401
Exhaust Gas Recirc.Flow Insufficient Detected
VW Golf iv 1.4i 036906032D 3398.rar
Witam, chciałabym zapytać, czy jesteś w stanie zrobić coś pod mapą w sterowniku silnika renault megane 1,4 8v miałem zamiar zwiększyć dawkę paliwa momentu obrotowego i strzały z tłumika? Samoch?d jest na imprezach i chciałbym to efekt ognia. Chciałbym, żebyś mi pom?gł
Hello I need egr off
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
Your file is 018DQ to be exact.
Not true my friend
If you disable SAI through MSLUB you requesting 0kg/h flow from pump so it won't start pump and will show readiness "PASSED"
ECU won't throw DTC because the requested flow will match.
I can't find MSLBUS though. But try the attached file and leu us know. Some files does not have MSLBUS
I 00'ed MSLUB and edit ESKONF to let you unplug the pump.
4B0906018DQ (VW Passat (SAI OFF) - 394791).zip
If you find my post helpful please hit Thanks button.
You can also hit Reputation button if you are kind enough.
if anyone need some file im online for some time
Hello, can someone disable dtc P0016 from this file?
Alfa romeo 159 jts 0261s01041 377864alfa romeo.rar
Thanks in advance
