I own a VW Passat B6 2009 2.0 TDI CR 81 kW 110HP.
Can you give it more power, like around 150 HP
That would be really awesome and I will appreciate it
BMS46
hello, great concept this
can anyone please help or are these ECUs to hard to work with?
i was fooled by banned member DesseD to pay for a file and it bricked my ECU. so AUD350 latr i want to give it one more go at tuning this car..I have 318i BMW 1999 with the BMS46 ECU.
thr engine needs more mid range torque and a 7,000 RPM
the torque limiter id think is an issue?
thankyou
kind regards
Ryan Williams
could you help me with my vw passat 2.0tdi -07
want some extra power
HW:
SW: 1037399388
VIN nr.: WVWZZZ3CZ7E150690
SW ver.:
Spare:
Engine: R4 2,0L EDC
HW Ver.:
SW upg.: 03G906021NK 9972
Hello guys,can anyone do egr off VOLVO S80 2005,D5
EDC15c11
HW:
SW:
VIN nr.:
SW ver.: ID MANU = 1820
Spare:
Engine:
HW Ver.: ID CHIP = 0C43 AMD 29F400BT
SW upg.:
Installation: SIEMENS C167
Bitte überprüfen Sie die mot-Datei
Can i have please stg 1 for VW PASSAT 3C B6 BMP ? thank you !
Hello
Cold someone please be so kind and remove DPF and Flaps on this EDC16CP34
Thanks a lot
Hello is it still up to date?
Can you help me?
Audi A4 B7 2.0 TDI BRD 170HP.
Stage 1??
Many thanks in advance!!!!!
Forgive me my bad school English
I need help with someone who can look over another guy's bin tuning file, as he did to my car
for The car is going so very fat and bad.
I should drive with 3bar or 4bar with these Saab injectors To match the K04 Hybrid Turbo
1. K04-0001 53049500001 5304-950-0001 (Hybrid Turbo Good for 250-260Hp)
2. 3 or 4bars fuel pressure regulator. (FUEL PRESSURE REGULATOR SKODA 1.8T VR6 4 BAR)
3. Saab red top injectors: Bosch 0280150431, Flow Rate 3 bar / min, N-heptane 260.0g (371cc) Resistance 12.00 Ohm
4. MAF Housing, "TT / VR6" 2.75 "ID (3" MAF (~ 76mm) = S4, Note VR6. VR6 is ~ 2.75 "/ 70mm).
5. Silicone turbo inlet hose (TIP)
6. K & N 33-2128 sports air filter.
7. Spark plug - NGK BKR7EIX.
8. Down pipe with race catalyst.
9. Milltek Cat-Back - Resonated with Stealth Tip (For Skoda Octavia 1.8T 150-180)
10. 14 lbs flywheel single mass, VR6 clutch
11. Boost Valve - N75J - 034906283J
12. Skoda Octavia 1.8T AGU (ECU M3.8 (06A906018CG) (Drive by cable)
(Edit) did, fixed, done
Hi.
Opel Omega 2.2DTI (Y22DTH), ECU - EDC15M
EGR off+more power plz. Tnx
hi
need some damos for winols to pathfinder denso 7058
please egr off ford ranger 2.2 with sid208
Hi!
Nissan primastar EDC15C3 ( renault trafic) , I need disable MAF sensor !
Hi i have edited the egr hysteresis map and removed the insufficient flow egr dtc, I would like +10% more power but don't have the knowledge/confidence to do so, I have included both the original map I read from the car via mpps + the map which I have edited egr on, your help is much appreciated thanks.
car has been fitted with gt1749 hybrid 1.6 bar max safe boost,(pd150 size billet compressor, pd130 turbine) uprated intercooler piping, egr delete pipe, and 3 bar map sensor, it already has a remap but the mapper had to bring the power figures down during mapping as the clutch started to slip, it's now been changed so would like more power.
vw golf mk5 1.9 pd bkc 105hp
03G 906 016 CB
028 101 190 0
EDC16u1
Last edited by dannyanto9292; 12th November, 2018 at 02:30 AM. Reason: adding more detail
