can anybody change dpf off?
please with correct cheksum
fiat ducato 2.3 mjet
Hi can you remove Adblue from this file? it's already dpf and egr off from edc17c64 audi.
Tks
disable pre-injection
FORD mondeo ii 2001 visteon 3S7AVF PUQQ5HD 85kW TDCi, stage 2 would be the best, but stage 1 is excellent too. And P2051 needs to be deleted, if easier to delete all dtc it would bew excellent too . I readed the file with KESS as 85kw ford mondeo diesel with delphi ecu, since it is first year cars of Mondeo II it has 256kb map file size.
i need hyundai edc17c08 neutral file can you help?
We need a tuning file for the Fiat fiorino vehicle we use in our own workshop. I'm adding the original file. Thank you for your interest ..
Need help whith a denso 1.7 cdti astra j dpf off.software dpf remover v3.0 asc etc not ok
A17DTS
DELCO
DELPH0100
SW:86ABV2H041060183
If you can help me, i need the stage 1 for Dacia Logan 1.5 dci 63kw euro 4
Here is the original file.
Thans
can you help me with speed limit deactivation?
Thank you!
https://mega.nz/#!XptghA5K!3klKmxrlf...j79NRc2zz9_FMo
please, someone can help me with swirl flap off W211 320CDI EDC16C2. The car run in limp mode with dtc P2009. I test delete DTC, but car run in limp mode without dtc.
Hello, please + 15%, egr off, for vw passat edc17c46, dsg, thanks good day
hi to all
can anybody help with dtc OFF
DF137 P0089
Renault clio 1.5 dci
car is start and work fine
Please can you remove P0341 from this transit sid 208/209
Hello. Could I ask for help with immo off or virgin?
C4 Grand Picasso
