Page 81 of 219 FirstFirst ... 3171767778798081828384858691131181 ... LastLast
Results 1,201 to 1,215 of 3273
  1. #1201
    Mar 2019
    2011 6.6 GMC Duramax 2500 - DPF Delete program,
    Would be much appreciated. Thank you
  2. #1202
    Mar 2019
    thanks friend
  3. #1203
    Dec 2016
    PL
    Im need V-MAX off in Citroen Berlingo 2015r, EDC17C10.
  4. #1204
    Mar 2016
    roma
    Default edc17 audi a3 140cv
    hi,
    I need a chiptuning for audi a3 2.0 tdi 140cv cr CBA motor with DPF installed.
    thank you
  5. #1205
    May 2019
    2015 vw passat 2.0 150hp
    i need tune please
  6. #1206
    May 2019
    Please remove DPF. It is Ford kuga 2013,DCM3.5. Thank you!
  7. #1207
    jameshal18's Avatar
    Feb 2018
    EU
    hello friend you can try this solution. no checksum corrected. pass by pm. make sure you reset dpf by diagnostic before writiing.
    DV41-14C204-CM dpf off no cs.rar
    If i helped, press THANKS and Reputation
  8. The Following User Says Thank You to jameshal18 For This Useful Post:
    hetzer (19th May, 2019)
  9. #1208
    Mar 2018
    Serbia
    Quote Originally Posted by ATOMIS View Post
    Try this file..
  10. #1209
    Jul 2017
    Do you have bmw e90 330d auto 0281013253 1037387658 original file?
    Thank you
  11. #1210
    May 2019
    Any maps for Alfa Romeo 156 Sportwagon 1.9JTD 16v 150hp
    Fiat Hardware Number: 55196563
    Bosch Hardware Number: 0281011984
    Bosch Software Number: 1037372327
  12. #1211
    Default edc17c10
    hello, can someone disable P1435, P1434, P0460
  13. #1212
    Jun 2011
    portugal
    Default tune opel astra 1300 cdti more power low rpm
    help friends
    best regards
  14. #1213
    Brolk's Avatar
    May 2016
    ARGENTINA Bs.As
    need off 2da sonda lambda
    fiat punto
    marelli iaw 4df cp
    tks in advance
    Brolk..
    Press "THANKS" button.
  15. #1214
    Netherlands
    Hi all,
    I need to remove DTC P0601 from MED9.5.10
    ECU Bosch 03C906056CP instaled in A3 8P 1.6 FSI
    impossible is nothing...
  16. #1215
    I need a chiptuning for a mercedes w211, 2,2cdi., sw no: 1037376891
