Page 93 of 218 FirstFirst ... 43838889909192939495969798103143193 ... LastLast
Results 1,381 to 1,395 of 3268
  1. #1381
    Senior Member sazimam11's Avatar
    Jan 2012
    Praha, Czech republic
    HI, can you help me with MED 17.5.1 ,please see here : https://www.digital-kaos.co.uk/forum...-1-DTC-removal
  2. #1382
    Aug 2019
    Deutschland
    Default More Power
    I would need the maximum on level 1 for an Audi A4 B7 Bj 2005 with a BDG engine. Attached both files, the original and the modified. Is it possible to get a little more power out of the modified one without having to change the hardware? I would be glad if you write me a good file. Thank you so much
  3. #1383
    Hello Please help me with Dpf OFF Egr OFF for Ford Transit 2.4TdCi SW#8C11-12K532-ALJ
  4. #1384
    Dec 2018
    Proszę o więcej mocy samochód Fiat Ducato 3.0
  5. #1385
    Jan 2019
    I can screw and diagnose, for chiptuning I need your help
  6. #1386
    Oct 2016
    Hello companions need more power in this car audi a3 1.9 tdi 90hp year 2000 ecu edc15v
    eeprom: st M27C1001 PLCC32
    engine: ALH
    need stage 1
    thanks and regards
  7. #1387
    DK Veteran mariazo84's Avatar
    Default dtc off p0341
    hola necesito p0341 apagado en archivo tahnks
    ecu 9664113480
  8. #1388
    Junior Member zafiraA's Avatar
    May 2011
    nottingham
    Hi can you rework a map file for me, its not quite what it is supposed to be or can i have a map for a w204 c220 cdi more power, dpf off, egr off please
  9. #1389
    Jan 2018
    Hello I would like to have more power, cut limiter egr off, dpf off. Mercedes sportcoupe 143hp 220cdi. 2003
  10. #1390
    Usa
    HI
    I need egr&fap off
    Dacia duster 1.5 DCI sid306
  11. #1391
    Nov 2018
    Default Stage 1 Caddy TDI
    Need stage 1 + EGR off
    Caddy 1.9 TDI
    Engine: BLS
    Gerarbox: Automatic
    EDC16U34 - 03G906021AR
    I use MPPS
  12. #1392
    Jan 2018
    Thumbs up
    Please help me DPF,EGR off and it will be super if you add more power.
    Ford Focus 2.0 tdci 2009 100kw SID803a
    I report and like later
  13. #1393
    Jun 2018
    Default egr off stage 1
    hi, ive had a nightmare doing egr off and slight power increase on this file. could someone help me and tune it with a bit more power more fuel efficient and egr mainly please. thanks.
  14. #1394
    Aug 2019
    Hi there
    I am after a tuning file for a opel corsa 2004 cdti 1.3 ecotec, I would be very grateful for your help
    Thanks Stez
  15. #1395
    Aug 2019
    Hi there
    could help me with tuning file for a opel corsa 1.3cdti 2004 ecotech, would be very grateful
    thanks stez
