can you please help me with this file from s4 b5 2002 aa box pleas remove rear os2 off and EGT off more hp
please need delete DTC U1218
edc17C60
THX
If my post was helpful, click the Reputation and Thanks buttons
X-TOOL, BESTDIAGCAR2014, DP3, GALLETTO V54, KESS V2, KTAG, FVDI2018, NEO X, VVDI prog, VVDI BMW ALAT, VVDI2,IDS MAZDA-FORD, iPROG+, AUTOOTUNER MASTER,MAGICMOTORSPORT FLEX MASTER,KEYMASTER,AUTEL IM608PRO
AUDI A3 2.0 fsi
Witammoże ktoś mi pomóc przy remove klapie wirowej na tej mapie
HI I need help egr off + cheksum...307 sid801A
please
here is 29F400 FLASH (IO terminal reading)
.Hello. I need help requesting a peugeot 4007 egr system bypass.
Help please delete DPF EGR DTC OFF Peugeot 807 2.2 Hdi
hi everyone ,
can someone pass stage 2 or more (to the limit...) on my stage 1 map ? with rev limiter, pop corn ...?
BMW E90 320d 177ps 2008
stage 1 file is egr/dpf off by tunerteam THX TO HIM )
https://mega.nz/#!EJkVSIrD!GK2tUJUza...ad_9CBmGUKbZsA
Hello!
Can You help me with this car?? now he has 106HP it will be fine 130HP,can You do it for me??Also i need cheksum ok because I'm using Galletto and it not support checksum....
DUMP.rar
HI.
Can you help me with more power on MAZDA6 2.0L 1ST
Hi, I would really appreciate if you could help me with this one for my own car.
I've got m52b28 engine, running on MS41.
Things i'd love to be done are:
- hard limiter set to 6800rpm
- pop mod
- maybe lambda delete if it's possible or any power increase? Don't really know much about this, because there're tons of different opinions.
Big thanks in advance.
Regards
Üdvözlet!
Szeretném megszüntetni az EGR-t.
Opel Astra f x16xel.
Delco multec F
16227869KJ
lehetséges?
Köszönöm.
I'm sorry! Here it is in English.
Greeting!
I would like to eliminate EGR.
Delco multec F
16227869KJ
Possible?
Thanks.
peugeot 308 2.0 180bhp with 6 speed automatic gearbox.
from what I know gearbox can be tuned from the ecu file.
stage 1
and if possible:
tva off
torque monitor off
speed limiter off
no available damos, from everyone I looked
some more pony for this fiat grande punto
