thanks friend
thanks friend
Im need V-MAX off in Citroen Berlingo 2015r, EDC17C10.
hi,
I need a chiptuning for audi a3 2.0 tdi 140cv cr CBA motor with DPF installed.
thank you
2015 vw passat 2.0 150hp
i need tune please
Hello,
Please remove DPF. It is Ford kuga 2013,DCM3.5. Thank you!
hello friend you can try this solution. no checksum corrected. pass by pm. make sure you reset dpf by diagnostic before writiing.
DV41-14C204-CM dpf off no cs.rar
If i helped, press THANKS and Reputation
hetzer (19th May, 2019)
Hello,
Do you have bmw e90 330d auto 0281013253 1037387658 original file?
Thank you
Any maps for Alfa Romeo 156 Sportwagon 1.9JTD 16v 150hp
Fiat Hardware Number: 55196563
Bosch Hardware Number: 0281011984
Bosch Software Number: 1037372327
hello, can someone disable P1435, P1434, P0460
help friends
tune opel astra 1300 cdti more power low rpm
best regards
need off 2da sonda lambda
fiat punto
marelli iaw 4df cp
tks in advance
Brolk..
Press "THANKS" button.
Hi all,
I need to remove DTC P0601 from MED9.5.10
ECU Bosch 03C906056CP instaled in A3 8P 1.6 FSI
impossible is nothing...
I need a chiptuning for a mercedes w211, 2,2cdi., sw no: 1037376891
