Hey group I have a weird issue with my upa. I have never seen this before and tried messing around with it but no luck. Has anyone seen this?
This is a virus. Go to options and change
clip TOOLS
clip Options
clip hex editor
Put it like this;
limit: 25
hex group: 1
numbers line: 16
" The colors to your liking"
Speedoman57 (24th February, 2017)
Thanks a lot . I wonder how that happened? I've never had a problem with the upa. I use it for 9s12 micros and it works like a champ.
Bueno voy a explicar una vez m?s
que es un virus en su PC o Laptos
Trojan.exe
gXXX.exe
Recycle.bin
o win32.sality.I
Can also occur by a malicious script
Mate, I happen the same, you have upa clone, you must delete the directories of elrasoft, and install other UPA software, not the one you already have.
This is not a clone bought this from elrasoft from penko. And I don't see how it could be a virus as that pc is never online. But who knows I'm glad I got it fixed and my job is done. I appreciate you all
carbandit (24th February, 2017)
Mate, restores SO, and problema solved, That was my solution.
jomberykaso (24th February, 2017)
hi
Is there any change new update release for upa ...or final software update is sep.2015 ...and that it....????
Juancho18 solution did work. But if you all where curious here is what penko told me to do.
run regedit
(pc menu:start\run, input regedit then enter) delete this item HKEY_CURRENT_USER\Software\ELRASOFT\UPA-USB Suite\Device Programmer 1.2 or HKEY_CURRENT_USER\Software\ELRASOFT\UPA-USB Suite\Device Programmer 1.3 or HKEY_CURRENT_USER\Software\ELRASOFT\UPA-USB Suite\Device Programmer-S 1.0 Depend of upa-usb programmer (s) version you use close regedit run of upa-usb programmer (s) software
Dejfat (10th January, 2018)
solution works
When you use the
THANKS and REP Buttons
it gives energy to help more
Appreciation is the key
