This is the eeprom dump from the navi.
Thanks in advance
I recently did a navi retrofit mmi 2g to 3g in my audi a4 b8 2008, i bought all the parts from ebay germany.
Now i've called a few audi dealers for removing the cp but they refuse.
I have read the eeprom from the radio (mmi headunit yet done) to remove the cp in eeprom but i do not know exactly what to remove, can someone help me with what i need to delete exatly in the eeprom.
thanks in advance
Thanks in advance
kamelkamel (16th February, 2019)
you have to update the mmi from the service menu. using 3 cd that you can download from internet.
you can active service menu by vag. and you log using too button setup and car . pusch them in same time
it's my pleasure to help you
Hi hk,
i understand that you write fastly and shortly and unfortunatly for me i'm a newby and not a good english writer as well ! :-) but despite it, i'd like to understand if there are a way to read and write the eepromm that contains the CP. im not sure if someone has got the algorithm that allow the calculation of the cp, but i'm sure that i0ve recently make my mmi virgin by mistake ! and now ive no mmi on my car, because no audi dealer can remove cp from virgin state mmi. Can you help me to undertand ? Ty.-
not possible remove cp by eeprom till now, for same unit its just enought to swap eeprom, about upgrade i dont know, better use odis online and its easy..
If I helped, dont forget use buttons reputation+thanks
I am looking to replace my Audi a1 2013 headunit that is faulty.
I have now purchased three different headunits in hope it was plug and play however im still no better off accept one is a Q3 Nav Plus as this one has the bose activated already.
The factory unit is as follows..
Delphi 18S VRMC Ccnt Nav
8XO.035.193F
SW 0801
HW H53
193F2835860912332117L
This also includes the Bose amp fyi.
I have purchased a second hand replacement unit and took this time to upgrade to the following unit also out of an Audi A1
Delphi 12S RMC NAV PLUS
8XA.035.192.F
SW 0186
HW62
192F2856348718230008S
After installing everything in i am dealt with component protection error and no sounds.
please can someone advise me of my options moving forward.
I can only access a friends VCDS and have an OBD11 reader Carista.
Please please help!
I have the original ee prom so could i simply swap them over?
Thank you for your help.
