You have problem with intake air leak or EGR. Removing DTC - bad idea.
Hello, is there anyone who could help me to remove the DTC P2279 FLASH.rarfrom this file. Thanks in advance!
gazvts (1st March, 2017)
also For a correct work you need to read that file in Bdm
I know not with what weapons
World War III will be fought, but
World war IV will be fought whit
"sticks and stones"
0soinsa (4th March, 2017)
The problem has already been solved, have been eliminated butterflies inside the collector, however, it remains the engine failure light on with P2279
the file is already read in bdm with trasdata
NO ONE CAN 'HELP ???
kinketotua (19th April, 2017), stanislav georgiev (26th February, 2017)
not solve the problem, may I help someone?!
Explain, what is the problem after pike file? If dtc was deleted then you must have another problem, not the same p2279
gazvts (1st March, 2017), kinketotua (19th April, 2017)
Pike file was done just only the checksum, the DTC has not been removed!
Obviously you have not fix the problem or wouldn't have this fault so +1 for more time spent diagnosing the problem instead of deleting dtc
miroopel (24th November, 2021)
chipdanix (1st March, 2017), kinketotua (19th April, 2017)
the problem is on the intake manifold, I have solved more than once so, eliminating the dtc.
Pike know this ECU wery well , but maybe he made some mistake.If i was on his place i will first read your posts and when i see that your posts is - help , i need ect ect i will not help you.This forum work - help to be helped.
chipdanix (1st March, 2017), kinketotua (19th April, 2017), konq100 (1st March, 2017)
Friends i can tell you! In OPEL some times CANT DELETE DTC CODES VIA DTC CLASS TABLE!! In my practic i have 3 cars who all time show Deleted DTC!!!! for reset that DTC need use other way.
