Results 1 to 3 of 3
    Jun 2016
    Default Disable DTC codes EDC15 SWAP 1.9TDI ALH
    Hello. I work with audi 80 quattro with ALH 1.9 TDI engine. This is my file from this car. How Can i disable DTC codes. I have foult wiyth ABS, Airbags and brake switch
    This is my DTC codes:
    3 DTC's Found:
    18044 - Powertrain Data Bus: Missing Message from Airbag Controller
    35-10 - - - Intermittent
    18057 - Powertrain Data Bus: Missing Message from ABS Controller
    35-00 - -
    16955 - Brake Switch (F): Implausible Signal
    35-00 - -
    Can You help with disable this dtc codes? Thanks
    This is my ori file:
    Mar 2016
    Sweden
    Default DTC
    PLEASE FILE DTC OFF PASS PM
  3. The Following User Says Thank You to sonic 1989 For This Useful Post:
    yakubu21 (25th February, 2017)
    Mar 2016
    Sweden
    Default DTC
    TESTED AND REPORT
