Hello
I need to disable immo function in Fiat Stilo 1.6 IAW 5NF.T1. I read EEMPROM 95160 from ECU. Could you disable immo/ or make it virgin ?
IAW5NFT1_oryginal_95160.rar
Thanks a lot & Best Regards
fezzy123 (31st March, 2020), gkogkolos (26th March, 2017), johny12345 (28th February, 2017), kluczbum (9th January, 2023), marcoane (20th May, 2020), mindafuttu (9th April, 2020)
Please help me the eeprom 95160 under what p did you read it 93cxx 24cxx thank you
Sent from my SM-T231 using Tapatalk
Hi Baltazar, thanks for dump. One more question: Should I change wiring (pin 12 and 16) of power supply of ECU or its not necessary?
Hi again,
After reprograming EEPROM using above dump immo function is disabled. The problem is that buzzer is beeping and immo indicator lamp is flashing. Any idea to solve thiss issue?
Not need to do nothing in BSI ,Immo off need to be done in ECU ,If you make good modification on ori file then lamp no flashing and buzzer no buzzzzzz.No need to cat any wire.
What keys when Immo is off ?
jenya (6th October, 2022)
I know post is old...i need a working pinout for this ecu! Iaw 5NF T1. Im trying to do out the car, voltage is 12v but no response from ecu.. 0 amps give me
Trying with v54 to read eeprom to do immo off without desoldering... In case its not posible, any photo were to drill on the back? Desoldering all pins really Hard!!
If theres any more solution, please share!!!
Many thanks friends
