Results 1 to 7 of 7
    Mar 2011
    Default Ford Focus MK2 Instrument Cluster Pinout
    Hello,
    I need pinout on instrument cluster on Ford Focus MK2 2005 with one grey 32 Pin Connector.
    Thank you in advance!
    neksus's Avatar
    Jun 2013
    Quote Originally Posted by hristopm View Post
    Hello,
    Here...
    Pins Programacion 9S12XHZ2512.rar
    PRESS THANK + REPUTATION
  3. The Following 5 Users Say Thank You to neksus For This Useful Post:
    boxsport (25th June, 2020), gladiatoris1 (30th November, 2023), leotdx (15th January, 2019), MARIKO (28th October, 2018), _estima_ (19th September, 2019)
    Mar 2011
    Thank you neksus
    but I need pinout of the big one 32 pins connector (with power supply, ground, can bus etc...)
    Mar 2017
    Hi, did you manage to get the pinout? I need it as well for the same 32 pin connector.
  6. #5
    Dec 2009
    here is the pin out for this cluster
  7. The Following 12 Users Say Thank You to rastus86 For This Useful Post:
    asto (1st June, 2022), Best Bandit (10th September, 2021), boxsport (25th June, 2020), danielif (5th November, 2019), Dr Alex (8th February, 2020), eliah (20th March, 2021), leotdx (15th January, 2019), m35i (2nd February, 2021), pedrod2005 (4th August, 2021), sokolomo (19th May, 2023), Viktor70 (22nd February, 2020), x_tacho (6th June, 2020)
  8. #6
    Jun 2014
    Hi which is ignition wire . As there the is battery + and ignition + best Regards
  9. #7
    Mar 2019
    Quote Originally Posted by rastus86 View Post
    has anyone all the 32 pins the pinout
