Results 1 to 12 of 12
    Aug 2015
    Default passat b6 DTC delete
    Can i have DTC P2015 intake mainfold position sensor (bank1) deleted WITH CHECKSUM PLEASE?
    It is passat b6 2.0 170 bhp 2009 year.
    ecu 0 281 015 029
    kess boot mode ID:
    HW:
    SW: 1037506138
    VIN nr.:
    SW ver.:
    Spare:
    Engine:
    HW Ver.:
    SW upg.: 03L906022KP 6213
    Installation: P151 - Bosch EDC17CP14 internal flash VAG
    passat-b6-edc17-ori.zip
    baltazar3's Avatar
    Andromeda
    Quote Originally Posted by dtip View Post
    ecu 0 281 015 029
    kess boot mode ID:
    HW:
    SW: 1037506138
    VIN nr.:
    SW ver.:
    Spare:
    Engine:
    HW Ver.:
    Here is ...try...allow tool to calculate CHK
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
  3. The Following User Says Thank You to baltazar3 For This Useful Post:
    dtip (4th March, 2017)
    Aug 2015
    I have kess china reworked , will it calculate chksum ok?
    baltazar3's Avatar
    Andromeda
    It should calculate chk ok
    Aug 2008
    why not fix the car rather than just deleting the dtc?
    all this is doing is making things harder to fix with no dtc
  7. The Following User Says Thank You to tango For This Useful Post:
    morgano (6th March, 2017)
  8. #6
    Aug 2015
    Quote Originally Posted by tango View Post
    I don't know really, you should ask that car owner....
  9. #7
    Aug 2008
    why when its you thats asked for it removing not the car owner?
    if car owner said to me remove this dtc from cars ecu, i would say no get the fault fixed and not try to hide it
    if he sells the car now the new owner will never know theres a problem that could result in a blown engine
    do you think this is fair????
  10. The Following User Says Thank You to tango For This Useful Post:
  11. #8
    Aug 2015
    Fair? Do you think mileage correction is fair and do you really think everyone here does it becouse of cluster swaping? Do you think it is fair to use and encourage others to use cloned software and hardware and even helping them by activating it like for example you do?
  12. #9
    Jun 2013
    EU
    Mate please, do not include everybody in same bag.
    I don't do (for example) mileage correction at all and i also don't hide faults like tango said.
    You really should encourage car owner to do proper repair.
    That kind of things is why workshops have everyday its reputation lower and lower.
    Regards,
  13. The Following User Says Thank You to morgano For This Useful Post:
    tango (6th March, 2017)
  14. #10
    Aug 2015
    Quote Originally Posted by morgano View Post
    Regards,
    Why don't you also encourage customers to change new swirl flaps for example, instead of deleting them out of map?
  15. #11
    Jun 2013
    EU
    I do believe me.
  16. #12
    Aug 2008
    i dont do any milage correction i have been asked if i can etc and always reply with i can but i wont so dont try saying otherwise and for software activations etc its not the same is it?
    hiding a fault on a car is not the same as using cracked software or changing millage etc
    hiding a fault on a car that could do damage to the engine and any new buyer of the car wont know hes bought a time bomb
    and turning dpf/egr/swirl flaps off in sw and removing them from the engine isnt damaging the car engine is it?
    so dont compare them
    removing a dtc to fool people into thinking the engine is in good working order when its not is not good
    enough said
  17. The Following User Says Thank You to tango For This Useful Post:
    morgano (7th March, 2017)
