Hi, anyone help please? I have ECU being shipped into my country as we speak. Just want to ask about the procedure to remove immobilizer from new ECU?or reprogram new ECU to old immobilizer?
Hi all, driving a Fiat Bravo 1,4tjet. Was flashig with Kess V2 China clone, write completed, now car doesnt start. Fuel pump doesnt activate when key turned to ACC, car cranks but doesnt start (obviously, no fuel). I think i have officially bricked my ECU.
My question is i hope fellow members can help:
I tried ECU swap with another Fiat Bravo (same model), fuel pump comes on when key turned to ACC. Car cranks but doesnt start. Im guessing its the immobilizer.
I have managed to source a replacement ECU (USED part, from another car, same ECU model), but hope others can share what are the potential problems with immobilizer and solution to get car up and running again?
Thank you all kind souls!
ECU: Bosch 0261 201 687
kind regards,
Mat
Why not flash back your original ecu with the backup you read before making mods and write?
Or maybe you flashed a file downloaded from the internet not made from your ecu read?
pulsar2000 (5th March, 2017)
Hi Friend, thank you for reply. ECU unresponsive on bench, cannot put in bootmode thats why. I may have fried it during connection to bench power supply, thats why bought a new ECU. any way to disable immobilizer? or reprogram the current immobilizer on my car?
Swap eeprom from fried ecu with the one you are expectingn to arrive.
slickkon (5th March, 2017)
thank you friend, i will try to post a picture later? mayne you can help me ID the eeprom? from my memory it is ST 95160? is this correct?
Hi Friend, i am not sure what is DTC. how do i check this?
edit: i just check meaning of DTC. My OBD reader cannot access/detect ECU, i think it may be dead or i may shorted when connecting the ECU to Kess V2 bench.
Hi Friends, can someone please help me? which is immobiliser chip i have to transfer to the new ECU? I attach image for reference.
Many many thanks!
swap the 95160 eeprom
slickkon (8th March, 2017)
Thank you Ominimi, so i have 4 choices correct?
1) swap the 95160 chip hardware to the new ECU
2) extract 95160 chip data and write into 95160 chip in new ECU
3) Find IMMO off .BIN and write on the new ECU?
4) Find virgin .BIN and write to 95160 chip on new ECU?
