Results 1 to 9 of 9
    Feb 2011
    Poland
    Default Passat PPD1.2 DPF OFF
    Hello.
    Can someone help me with DPF off in this file.
    VW Passat 2.0TDI 170ps
    Siemens PPD1.2
    Volta and Ecusafe don't work.
    03G906018EM
    Jan 2014
  3. The Following User Says Thank You to nikobg For This Useful Post:
    MarcinL (11th March, 2017)
    Mar 2017
    Russia
  5. The Following User Says Thank You to Extremo For This Useful Post:
  6. #4
    Feb 2011
    Poland
    Nikobg your solution does't work. I haven't trouble codes, but dpf lamp is still on.
    Extremo thanks, but where is the pass?
  7. #5
    pawelelectro's Avatar
    Jun 2011
    Poland
    After flashing dpf off file you have to drive few kilometers and lamp go off.
    Ash counter should decrease in measuring blocks.
  8. #6
    Jun 2011
    Poland
    If this files dont work, write to me. I have tested solution
  9. #7
    Jun 2011
    Poland
    DPF OFF. No chk.
    Reset ash counter, write dpf off file.
  10. The Following User Says Thank You to pawelelectro For This Useful Post:
    MarcinL (15th March, 2017)
  11. #8
    Feb 2011
    Poland
    Thanks. It's works!
  12. #9
    Nov 2014
    Hi! Could I have pass? I'm testing a solution egt temp is under 700 deg no regen but ecu tries it.
