Results 1 to 5 of 5
    Jul 2008
    Default which memory test software can make logs ?
    hi everybody i have recently had some bad ram, which i bought from a shop and they said if i can produce logs of the errors it will speedup the return process. after trying just about every memory testing program i can find, i still cant find a program that can create logs. i have had mixed results from the program running for 24hrs or more then crashing leaving the pc totally unusable and obviously not giving the chance to make a note of any errors.
    thanks in advance
    Apr 2008
    The only app i can think of is called SiSoft Sandra Pro XII SP2c
    Go to google and type FOSI
    you'll find it there.
    Member Dazza's Avatar
    Aug 2008
    It's been quite a while since I used it last, but I have the feeling This M$ tool may give the option?
    V.I.P. Member biffo1's Avatar
    Mar 2008
    yep sandra soft or Everest will do it mate
    [CENTERhttp://i195.photobucket.com/albums/z39/biffo1/iOS-4322.jpg[/CENTER]
    Mar 2008
    memtest
    Memtest86+ - Advanced Memory Diagnostic Tool
    pretty sure it logs.
