Results 1 to 3 of 3
    Jul 2008
    Default Astra Electrical fault no reverse lights
    RIght Guys
    Got the Mrs a little astra '95 plate checking a few things out found no reverse lights.
    Checked fuse-okay
    Checked switch on transmission casing-okay
    Checked bulbs-okay
    Where do I go from here.
    Am assumin there is a cable break somewhere but how do I find it and where do the cables run
    Any help appreciated
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    how did u check the reverse light switch m8 .. very common fault
    Jul 2008
    Found the problem after another 3 hours of looking.
    It was the reverse light switch even though I had checked it
    Truned out my avo was knackered
    NEW LIGHT SWITCH AND NEW AVO TIME
    Thanks Smirnoff
