    Aug 2014
    Default bmw ms41 m52b28 rpm limit needed
    dear friends i have a ecu ms41.0 file is attached.Can anyone make rpm limit to 7k please?
    phl0at's Avatar
    Nov 2015
    Bulgaria
    As I can see it is already set ot 6976RPM. I will set it to 7040RPM.
    Here you go, pass in PM.
    BTW with this tuned file the car will knock a lot. At some points the ignition is advanced by 18 degrees, and the Knock tables touched a lot. Siemens MS41 is very very adaptive ECU and never stops adapting according to the Knock. The car is leaned out a lot and uncontrolable circumstances will occur because of all the maps touched inapropriately.
    Seriously, does the car pull well with this one ?
    ORJ BNM tuned-7040rpm.rar
    DPF/FAP, AdBlue SCR, EGR, Flaps, DTCs, Lambda, IMMO off, Custom REMAP
    *IPTV Provider
    Aug 2014
    Quote Originally Posted by phl0at View Post
    can you tune it for me?
    and with old value car rpm limit was not changed with originaL
    Aug 2014
    Quote Originally Posted by erdilmen View Post
    can you tune it for me?i tried change rpm before but nothing changed, i read ecu and i will attach now , as u said i think ecu adapted itself .Can u tune it for me?
    phl0at's Avatar
    Nov 2015
    Bulgaria
    Yes i can. Tell me if there are any mods made to the car.
    *IPTV Provider
    Aug 2014
    rngine is stock m52b28 stock , swapped e30, ecu is 5wk9 0322 index 11 dme ms41.0 // 1 429 861
    first file i send u it was not right, i will attach again,which file i read from ecu again.Important think is i need rpk limit is 7k please
