Hi friend, i have ford focus 1.6, year 2008 with ecu edc16c34. I have remove DPF, and all is ok, but this car, have additivation container broken and message on dash.
Is possible remove additivation from file?
Or i have IDS ford, but I do not know if with this, i can remove additivation.
Is possible help?
Hi frien, thanks.
Your file is 100% tested?
eiemax (14th March, 2017)
need to disconect module aditive under passenger retro post?
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
mariusica_boy (14th March, 2017)
Hi friend, thanks. After disconnect, i have delete error, but is the same. I have reconnect connector and i have only p1992 error, with disconnect plug, i have p1992 and p1928
I have delete error but is the same. You have any other solution friend?
