janomari (23rd May, 2019)
Did you try the super known egr switch for edc15c2 & edc15c3?
I tried one bit solution. Maybe super known egr switch isn't super known for me ... I don't know what do you mean.
Your ecu is EDC15C13.
kierownikszatni (15th March, 2017)
Car won't start. CS checked. I read that this is common problem. As morfeyj said, this is EDC15C13 - I'v made mistake. Is it possible to swich Egr in this Ecu?
8 bit, decimal, 7273B from 1 to zero.
Cut 1 of the two ACTUATOR COIL wires and leave the connector plugged.
Regards!
kierownikszatni (15th March, 2017), kinketotua (15th March, 2017), konq100 (15th March, 2017)
This decision works well when EGR position sensor is OK.
Anyway there is another switch to disable signal from EGR position sensor but it is not public like first switch.
Best Regards.
bobolin4o (15th March, 2017), kinketotua (16th March, 2017)
Solved. Thanks a lot for tips.
