Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
  1. #16
    Aug 2015
    If I have uploaded several images but all the ones that boot no works the tuners
    The list of channels is updated to March 2017 could be problem of this when starting?
    Writing vfd
    !!!!! UNC read error occurred while reading from NAND flash
  2. #17
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Do you have a hdd inside and did you not back up image before you flashed do you know what image was on the box before hand? Is it a v2 clone?
    Sounds like a bootloader error as shaunfree was saying.
  3. #18
    Aug 2015
    thanks for answering
    Is a clone v2
    I have no idea what image I had previously
    Hdd does not have
    I think it's a boot problem, I think?
  4. #19
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    So you flashed bootloader and restarted box?
    You then formatted usb to fat 32 and put unzipped file called vuplus on it and reflashed from front of box without any other usb connected?
    No joy?
    Issue may be related to wrong bootloader or software or the security chip may need replaced. This relates to bad address in epc meaning it can't read it or software is wrong or it has failed.
    You could check the voltage that comes from the chip but I wouldn't advise that if you are not competent in electronic diagnosis.
  5. #20
    Aug 2015
    thank you very much
    I checked the output voltages of the power supply and they are correct
    The famous capacitors are changed
    And the voltage of the security chip is also checked and is ok
    What could it be??
  6. #21
    V.I.P. Member Fergal's Avatar
    Aug 2008
    Have you tried flashing this image on
    BlackHole-2.0.7-bm750_usb_Ferrari_V2
    https://mega.nz/#!4ggkGYSK!wAJBucDmFNRJjehhFHBomz8hGaRXkhLW0ETj7JpjrhI
    You might need to put the "boot_cfe_auto.jffs2" file in the Duo folder with the other 2 files that are in there
  7. #22
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Obviously if you've checked voltages changed capacitors etc you are competent enough to get the box working.
    Can you specify exactly what you have repaired on the box capacitors etc which ones and where?
    Can you tell us when you load an image that starts what satellite you are on and what the signal strength is and also post the configuration of the tuners?
    What image is starting? What channel list you are using?
    Have you tried each tuner individually?
    Can you post the voltages from the ic security chip?
    If at all possible post a few pictures of problems.
    Can still see it being security chip if tuners not working.
  8. #23
    Aug 2015
    Ok I have flashed it as you said and it stays the same thanks
  9. #24
    Aug 2015
    The capacitors change c 807 c 814 c850 c848
    The signal strength puts 99%
    Voltage tuner 13v but without signal
    Image blchole and openspa
    You pass image security chip security477-16c9895f4ca15fed4504355435d1a892.jpg
  10. #25
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Hi your box loads up and you have a great signal but it wont let you access tuners everything points towards the security chip being faulty.
  11. #26
    Aug 2015
    Ok, thank you so much
    Do you know if there is a way to buy?
  12. #27
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    No but I'm sure someone will have one lying around spare.
  13. #28
    Aug 2015
    It's solved thank you very much to all
    Solution = V2 upd_vu62k load the file po rs 232 and everything ok 100%
  14. #29
    Apr 2011
    Hi Malpi, I have had success with 1 of these with the same problem. PSU fix.
    Let me know if I can help.
    Regards,
    Jules.
  15. #30
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    The problem wasn't with screen starting as the thread suggested the problem lay within a faulty security chip which the v2 clone model has he has now sorted the chip as the post above mentions.
