Results 1 to 4 of 4
Hybrid View
    Nov 2014
    Default HELP REMOVE DPF EDC17CP14
    hi guys
    need help remove dpf from vw EDC17CP14
    ecu 03L906022Q
    PLEASE NEED TESTED SOLUTION
    nizarben's Avatar
    Dec 2013
    Default dpfoff
    your file off
    mp
    microfap.rar
  3. The Following 2 Users Say Thank You to nizarben For This Useful Post:
    philipcoin (16th March, 2017), pike (17th March, 2017)
    mariusica_boy's Avatar
    Quote Originally Posted by philipcoin View Post
    hi guys
    ecu 03L906022Q
    Your file dpf off.
    You can disconnect sensors temperature and senzor differential pressure from dpf.
    Pass PM.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  5. The Following 2 Users Say Thank You to mariusica_boy For This Useful Post:
  6. #4
    Nov 2014
    thanks to you all file works great ....
