Here is your file, pass pm, and thank you
Mercedes Sprinter 2008 year with EDC16CP31.
Error 2511-exhaust gas recirculation valve position.
Please if anyone can remove the EGR valve from the map.
Read with FGtech 4
Thank in advance
Sarkan (15th March, 2017)
Thanks.I'll try tomorrow
With this dump engine is no longer in Safe Mode.Engine has power.When I erase errors MIL lamp is off, but the error remains present in the ECU.If often start the engine MIL will remain off.If I leave it extinct for a long time when I start MIL light will remain active.Please note that all the time the engine is running well.
Check this flie.
Sarkan (16th March, 2017), stanislav georgiev (16th March, 2017)
unplug egr and mount resistor
Try this and report....
SPRINTER EGR OFF.ZIP
500R is ok
You have to make a total solution
Plug off!
Ecu powered, Dtc, Egr, Dpf, Throttle, Flaps, Lambda, Hotstart, AdBlue, Evap, Nox, Speed limiter, Dynotest development.
Finally I took the time to try.I disconnected the EGR, error is gone and the engine works well with a file from konq100.
stanislav georgiev (20th March, 2017)
