25C320, not 25C32.
25C320, not 25C32.
rtbdiagnostic (23rd November, 2018)
try with this dude... (using UPA)
Yes it is 95320
Send me a file
Here is the data of 650km
please can anyone tell me where to find the data on tachosoft ?
BDW I need 10km
try this..................
If not work then use this same algo but swap
Best Regards
r0adster (19th March, 2017)
Dear Sir,
I have this algo for suzuki
for 65,000km;
=Dec2Hex(65000/16) => 0FDE => swap => DE0F
XOR of DE0F =>21F0
Therefore; DE0F 21F0 is the hex calculation.
Can you explain how you calculate this 10 KM
00 00 FF FF
00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF
00 00 01 00 FE FF 01 00 FE FF 01 00 FE FF 01 00
FE FF 01 00 FE FF 01 00 FE FF 01 00 FE FF 01 00
hi
any honda alog
Niaz (19th March, 2017)
Tha algo is simple guys...it's found at $ec-$12b- 16x times
The factor is 32x in this instance,instead of 16x... then xor the following 2x bytes
You right sir,
But i have slightly issue;
First 6 bytes as 00 16 (Xor FF E9 only 5 times)
FF EF is 11 times (Xor 00 1B 10 times)
32X factor how can we apply to know the exact value of odo
If i take your example than 10KM should be 00 00 =XOR = FF FF from $EC-$12B
But Mr. Nizk write in two parts as follow;
00 00 6 times (Xor 5 times FF FF)
FF E4 11 times (Xor 10 times 00 1B)
How we can calculate 10KM in above example??????????
