Results 1 to 10 of 10
    Default A4 2.0 Tdi 105KW dtc remove
    I have trouble code P2015 please remove this code. Thx
    Ecu edc17cp14 0281014235
    Jun 2009
    Calculate CS
    P2015 off - 396484.rar
    Jul 2013
    romania
    Default immo off edc17cp14 audi a4 2008..need
    hello,i need immo off in my ecu edc17cp14 audi a4 143hp...ecu is 0281014235 03L906022B,i will atach flash int mpc1796 and eeprom in mpc too..separate..please need good immo from the original file with no dtc error in intrument cluster...the original ecu is damage...and i whant to put another ecu in the car...no clone and swamp flash and eeprom available in this type of ecu...please help..thanks,and by the way...is reading with k-tag
    alex09's Avatar
    Apr 2013
    Serbia
    Quote Originally Posted by cutiutza View Post
    Try this i think it should work, its done by avdi. If it works press rep. and thanks button.
    Jul 2013
    romania
    hy my friend,the file is not working... i have error p1570...engine control module disabled
    Jul 2013
    romania
    with more errors p1647,p1570,p0016.,p068a,p2015
    Jul 2013
    romania
    starts and than stops
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    STILL IMMO FAULT THEN
    Jul 2013
    romania
    can you help me with that?thanks
    Jul 2013
    romania
    solved,thanks anyway,DK partners
