Results 1 to 7 of 7
    Mar 2017
    Rio Branco /AC Brazil
    Talking Toyota Hilux Denso ECU programming
    Hi ppl, i',m trying to figure out how to program/reprogram Toyota ECU, actually i'm interested to work with diesel ECUs, i'm looking for software and correct interface to program those units, if someone can share experience any help will be welcome!
    Member satriawr's Avatar
    Mar 2016
    Jakarta, Indonesia
    BitEdit? Winols also can. I use BitBox and PCMFlash for that ecu,...
  3. The Following 2 Users Say Thank You to satriawr For This Useful Post:
    derbali01 (2nd September, 2017), ecufix (4th April, 2017)
    marsete's Avatar
    Oct 2010
    SPAIN
    Hello, for me the best is ktag, read and write and chks correct...
    Spain
    Hi, I also suggest ktag, works very good on this, even kess with virtual readings is good option too.
    Regards.
    DK Veteran elmassioui's Avatar
    Dec 2010
    ktag dont work on ecu toyota denso with mcu nec BGA but SMD work ok.maybe some bug will be fixed
  7. The Following User Says Thank You to elmassioui For This Useful Post:
    Brayn (12th June, 2017)
  8. #6
    Aug 2016
    what about kesd????
  9. #7
    Dec 2010
    Quote Originally Posted by hk06 View Post
    what about kesd????
    hi
    kess Not Tried Yet
