Hi. Due to changing the manifold I've make a short-circuit to the starter and now I have the abs /srs(driver one) and water level sensor lights in dashboard on. I try to change fuses but nothing happen then I remove and replace the relay and the same.. anybody now maybe where I should look to solve the problem or I should just replace the two sensors? Thank you
