Page 1 of 3 123 LastLast
Results 1 to 15 of 38
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Default How to Create your own Boot and Shutdown Logos
    Thanks to Fergy for the guide.
    Dimensions of boot, radio, mp3 and scan picture must to be 720x576 pixels in PAL format.
    Path where boot image are stored is /root/platform/kernel and named is bild
    Path where other pictures are stored is /var/tuxbox/config/enigma/pictures/
    Program what is usually used to make boot/background pictures is TMPGEnc ( in attachement is *.mcf template file what You can put into TMPGEnc's \Template folder )
    So little brief for using TMPGEnc without the template:
    #1 Download TMPGEnc from official site
    #2 Unzip the file to your chosen destination.
    #3 Double click the 'TPMGEnc.exe MPEG Encoder' file and click 'OK' on the small pop up window and then click 'Cancel' on the 'Project Wizard (1/5)' window that appears.
    #4 Next screen, bottom right...'Stream type', check the box 'ES (Video only)'.
    #5 Next, bottom left...'Video source:' click on 'Browse' and select the background/photo that you want as your new boot logo for the Dreambox.
    #6 Next, bottom left... 'Output file name:' click on browse and choose the path for your finished 'new' boot background/photo and edit the name to 'bild' (minus the '....' and in lower case) ie: the line that apperars in the 'Output file name:' should read similar to C:\Documents and Settings\Whatever\My Documents\bild ( the actual name of the photo does NOT appear).
    #7 Next, bottom right...click on 'Setting' and check that the value settings are:
    .....'Stream type:' = MPEG-1 Video
    .....'Size' = 720 x576 pixels
    .....'Aspect ratio:' = 1:1 (VGA)
    .....'Frame rate:' = 25 fps
    .....'Rate control mode:' = Constant bitrate (CBR)
    .....'Bitrate:' = 12000
    .....'Motion search precision:' = Normal
    When checked, click 'OK' to exit the screen.
    #8 Top left click 'Start', if all is goes well, the '100%' bar appears and your completed 'bild' file is to be found in your chosen 'Output...' location.
    Transferring the new 'boot' photo to the Dreambox.
    ENSURE that the image that you want to change the boot/radio background pictures for, is the image RUNNING in the Dreambox when editing.
    With the image, that you want to change the boot photo for, running in the Dreambox, open your chosen FTP prog and transfer your new 'bild' file to the path: 'root/platform/kernel', you can overwrite or delete the pevious 'bild' file that exists.
    Exit your FTP prog and reboot the Dreambox.
    You should, if all ok, see your new photo on the next boot.
    *** If You want to change boot picture before compressing image (after command make rebuild-flash ) , just copy it into /tuxbox-cvs/root/cdkflash/boot/root/platform/kernel before executing command make flash-compress.
    Get Digital Kaos on your Apple or Android device with Tapatalk
    DK Veteran Salami's Avatar
    Apr 2008
    Hi Kaos
    I take it the same of the above description applies on Dbox.TA
    V.I.P. Member Jaffa's Avatar
    Mar 2008
    Norn Iron
    Quote Originally Posted by Salami View Post
    Hi Kaos
    Dbox is easy compared to that, just use Logo viewer in the downloads section.
    Apr 2008
    Quote Originally Posted by Jaffa View Post
    I just downloaded it and looking to see how to use it.
    cheers M8
    May 2008
    We can use easylogo plug-in to do it as well
    Last edited by aftermath; 8th May, 2008 at 06:28 AM. Reason: Sorry no links to other Sat Forums
    May 2008
    I can?t find the bild named file in the dreambox 500c, is there any other way it could be named? also the kernel folder i have is empty.
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    What image do you have? There is no set rule with these things, depends on how the image creator has configured it at source.
    May 2008
    It is a image made by KGD team, is a spanish group making a fast dreambox image for dreambox 500, it is version 1 and has small failures that are going to be fixed in v2 and i am happy using it, but i would prefer to learn it internally but no info about lot of things, it uses tuxbox with enigma.
    I have just found that it is in
    /share/tuxbox/enigma/pictures/kgd.mvi
    not know how i can change it, can?t delete, can?t rename and can?t upload any file to that folder by ftp.
    any hint if it can be done by telnet etc?
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    /share is a read only part of the image.
    You can still change it though.
    The files in /share/tuxbox/enigma can be mirrored in /var/tuxbox/config/enigma. The image will use any files in /var before it uses the files in /share.
    So if you create your own boot image, rename it to kgd.mvi and put it in /var/tuxbox/config/enigma/pictures it should use that image.
    I think you need to use Tuxbox LogoViewer to create a .mvi image.
    May 2008
    It didn?t work uploading file to /var/tuxbox/config/enigma/pictures/kgd.mvi
    I found that in /etc/init.d/rdS and /proc/1/cwd/etc/init.d
    there is a call to
    /bin/showlogo /share/tuxbox/enigma/pictures/kgd.mvi
    I can?t change files, is there any other way i can try to change it to the file
    /var/tuxbox/config/enigma/pictures/kgd.mvi i have uploaded?
    note: I am going to try your tutorial about creating a dm500 image, could be more interesting make one that learn to change other people made.
  11. #11
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Have a look in the rcS file, is there a line that says..
    /var/etc/init
    If there is, does this line...
    ...come before or after it?
  12. #12
    May 2008
    In line 34 is
    And in line 153.
    if [ -e /var/etc/init ] ; then
    . /var/etc/init
    fi
    and in /var/etc/init file only this line
    if [ -e /var/etc/.tuxmaild ]; then /var/bin/tuxmaild; fi
  13. #13
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    You won't be able to do overwrite it then.
    There is a way, I'll post up a guide soon. You would need a linux PC though, can't do it in windoze unless you use vmware.
  14. #14
    May 2008
    I change the file init to
    /bin/showlogo /var/tuxbox/config/enigma/pictures/kgd.mvi
    then the previous image is shown for 1 second after that is shown the image i have uploaded.
    Not perfect thing but is better than nothing, i go to take a try to install linux on computer to try your tutorial about creating a image.
    Thanks for your help devilfish.
  15. #15
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Nice thinking. At least it's better than what you had.
