25814 is the correct pin , leave Ignition ON for 15-20 Min and try again .
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
eliasole (3rd April, 2017)
Also try to leave ignition on for some time without any result , dump is readed by odb with avdi , try to add key by dump with the help of effi ,wrote the file to bcm and after that car dont start at all with any of the dumps. I am afraid that there is no good read with avdi at the first place..
I upload both dumps ,ori and new ori (with added key by effi) so pls someone can repair it .
Thanks in advance!
Any help please.....
This is the Fiat Stilo Body Computer 46823770 !
Yes , i have bad read and at effi the dump it shows like stillo , my bcm is siemens-vdo S118578040l
eliasole (4th April, 2017)
It will never work bsi siemens with dump file from bsi stilo .
The question is where is dump from bsi siemens ?
This is a dump file from Fiat Panda.
Yeap , this is the case , i read bsi siemens with avdi and gave me dump like stilo?.... Make mistake and add key to that dump with effi and wrote it back and now car dont start. What i can do now to start the car? Make virgin ecu 6f3 and wrote a dump proper to that bsi and add key with new pin of dump?
If you do not have the original dump file you have a problem.
Use my dump file and try to log on Pin Code - 74559
If you succeed, make a key and virgin ecu 6f3
please pin in my dump BCM Fiat Panda 9S19DG128 1L40K
