Results 1 to 5 of 5
    Jun 2013
    Lithuania
    Default Opel Signum 1.9 CDTI EGR
    Hello, I was wondering if someone could help me out. Today I decided to turn off egr for my car, because the mechanical part is sticking so I put blanking plate but MIL is on p0400. It has edc16e9 ecu. I did few of these cars and Volta solution worked with this ecu's but on this it seems that it can't find it.... HW number is 0281011915, SW 1037384325. I have full BDM read with BDM100, I attach external flash dump:edc16e9 ext flash.zip
    Could someone check my file and see, maybe there are fault in reading or just my software doesnt support this ecu? Thank you for your time
    Jun 2013
    Lithuania
    Sorry my mistake, on BDM100 settings there was setting "Read/Write AM29bl802c files with EDC16 encryption" I cancel it and read is good, Volta recognize the dump
    Jun 2013
    Lithuania
    =/ Winols solution doesn't work... I attach full BDM read with Int and Ext flash, EEprom if someone need them in the future... Could someone help me out with this dump and make EGR off without p0400 (I leave EGR plug connected, electronically the valve is good). Opel edc16.zip
    carbon7319's Avatar
    Aug 2011
    Macedonia
    WinOLS (Opel BDM Flash Vectra-C (EGR off) - 384325).rar
    Egr close without error p0400.
    CKS is ok , only write with BDM100.
  5. The Following 3 Users Say Thank You to carbon7319 For This Useful Post:
    chipdanix (4th April, 2017), kinketotua (4th April, 2017), Milicija (4th April, 2017)
    Jun 2013
    Lithuania
    Quote Originally Posted by carbon7319 View Post
    Thank you very much! Car started, no faults related to EGR, duty cycle constantly 100 % (closed position), thanks again
