...AVDI Technical Support ONLY... - Page 53
Page 53 of 68 FirstFirst ... 343484950515253545556575863 ... LastLast
Results 781 to 795 of 1012
  1. #781
    115
    Downloads
    Uploads
    Does anyone know if you use the renew function on a 1997 Mercedes E300 Immo box if it just renews the key data or does it make the box virgin? and if it makes it virgin, is there a way to personalize the box back into the car with AVDI or Xentry?
    Thanks in advance...
  2. #782
    Gavra's Avatar
    Belgrade/Melbourne
    186
    Downloads
    18
    Uploads
    Quote Originally Posted by ps80l View Post
    I don't think you read my prior post where I mention I verified fuse location via diagspeed reference....I also looked at fuse diagram. I can't look at the abrites fuse guide as it doesn't exist.
    I meant to use WIS , ESItronic etc.....
    2006 C230 is W203 not W204 and Diagspeed get pass without relay.......something is not wright........
    Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
  3. #783
    115
    Downloads
    Uploads
    Are you sure it's W203 and not W209??
  4. #784
    Mar 2017
    62
    Downloads
    Uploads
    My friend did the same year and model w203 and had to connect to fuse 57 with his diagspeed. He got password in about 50 minutes.
  5. #785
    44
    Downloads
    5
    Uploads
    Mercedes 2006 C230...All keys lost.. Use the jumction box connected to the fuse box. Was reading extremely slow. After 1.5 hours it was at about 220 out of over 8000. After that cluster went black and abrites stop scanning. Had to remove EIS and eeprom it.
    Done dozens of this type on the bench using junction box,are you sure you removed the correct fuse ? if not sure check for power at EZS...
  6. The Following User Says Thank You to joemajdalani For This Useful Post:
    cqae (20th November, 2017)
  7. #786
    Mar 2017
    62
    Downloads
    Uploads
    Abrites has no reference... Checked fuse diagrams and nothing indicated eis/ezs..called my buddy who had done the same car with diagspeed and he said it was fuse 57. Description for that fuse in the diagram is "start enable"
  8. #787
    koln, germany
    55
    Downloads
    10
    Uploads
    I AGREE WITH you , but in the manal they said you need to check , they need to improove this point instead
    also getting pass method is gamblig , i like when costumer ask how much time will this long ? how much do i have to pay ? and i answeeer yeeeahh sure not for free
  9. #788
    Apr 2014
    185
    Downloads
    13
    Uploads
    Hi guys. Can anyone tell weather the Abprog ribbon cable is an ordinary printer cable or where can I get just the cable without buying the entire ZN030?
    Sent from my SM-G930F using Tapatalk
  10. #789
    Mar 2009
    45
    Downloads
    19
    Uploads
    Quote Originally Posted by trinicolin View Post
    I think its a straight thru cable. i.e. an extension cable.
  11. The Following User Says Thank You to madaxe For This Useful Post:
    trinicolin (20th November, 2017)
  12. #790
    koln, germany
    55
    Downloads
    10
    Uploads
    BUT YOU Need to get option and ab prog to get it work
  13. The Following User Says Thank You to isma123 For This Useful Post:
    trinicolin (21st November, 2017)
  14. #791
    May 2016
    17
    Downloads
    Uploads
    Chevrolet Cruze (BCM). Immo light keeps on all the time. Reads pin ok. Shows two keys.
    When programming keys Abrites says keys deleted ok but right after comes text "Operation failed - Device Control Limits Exceed" and keys stays in the system.
    Any ideas?
    Edit: It was key problem. Somehow original key gives "Operation failed - Device Control Limits Exceed" when ever inserted (firs/last...)
  15. #792
    65
    Downloads
    6
    Uploads
    As always last time avdi will be the last tool in the market that supports MQB heh
    ABRITES Diagnostics for VAG
    Published: 21 November 2017
    ABRITES is extremely happy to announce that the long months of development in our VAG department are now achieving the results that we all hoped and the next software release will contain support for the MQB platform. The first function that will be released is going to be mileage recalibration for the following models with instrument cluster Continental/VDO:
    Audi A3/S3 2014+ Audi Q2
    Seat LEON 07.2014+ Skoda FABIA/OCTAVIA III 07.2014+
    Skoda RAPID 06.2015+ Skoda KODIAQ/SUPERB III
    Seat IBIZA/ATECA/TOLEDO 06.2015+ Volkswagen Golf 7/Polo/Tiguan II/Touran II 07.2014+
    Volkswagen Crafter 2017+ Volkswagen Passat B8
    We are also currently in the development stage for a key programming solution and will let you know as soon as we are close to releasing the necessary functionality.
    Thank you for keeping your faith in us so that together we can continue achieving the impossible!
    also they cloning io terminal for opel/gm bcm
    Abrites Diagnostics for Opel/Vauxhall
    Published: 10 November 2017
    The latest update of the Abrites Diagnostics for Opel/Vauxhall will contain added support on the following fronts:
    Key Learning
    The new and improved key learning function now supports programming of keyless keys for Opel Insignia/Chevrolet Cruze. Key learning has also been added for certain Buick, Cadillac, Chevrolet and GMC models.
    NB! The new function is available for owners of the ON013 special function. Customers with older key learning functions will need to use the "Legacy mode" special function.
    Read Security Code
    • Engines: E38, E39, E39A, E78, E83, E92
    • Instrument Panel Cluster with 4.2 inch Color Display - Insignia Facelift (2013-2017)
    • Instrument Panel Cluster with 8 inch Color Display - Insignia Facelift (2013-2017)
    • Body Control Module - Insignia Facelift (2013-2017)
    • Body Control Module - Corsa D
    Read/Update ConfData
    • BCM Delphi 70F3238 (93C86) - Read/Write - Corsa D
    • BCM Delphi 70F3379 (93C86) - Read/Write - Corsa D
    • BCM Delphi 70F3633 - Read data flash - Meriva B
    • BCM Bosch 70F3385 (24C16) - Read/Write
    • BCM Bosch 70F3469 (24C16) - Read/Write
    • BCM Bosch 70F3558 (24C32) - Read/Write
    • BCM Continental 70F3469 (95160/25160) - Read/Write
    • BCM Continental 70F3558 (95320/25320) - Read/Write
    Please expect the updates over the coming weeks!
    SO STILL NOTHING NEW IN AVDI SOFTWARE
  16. The Following User Says Thank You to i-vtec For This Useful Post:
    solitaire (21st November, 2017)
  17. #793
    Aug 2015
    162
    Downloads
    Uploads
    I hope mqb update will BE free of charge.
  18. #794
    65
    Downloads
    6
    Uploads
    hheh i thinking no way, lower price will be 1000 euro
    they nothing do by yourself from long time ago, look
    bdc/fem - cloning of bmw explorer
    mqb - cloning dp4
    opel bcm - cloning ioterminal
    renault ecu - cloning renault ecu tool
    etc etc
  19. The Following 2 Users Say Thank You to i-vtec For This Useful Post:
    solitaire (21st November, 2017),ttzag (21st November, 2017)
  20. #795
    Moderator
    PremierD's Avatar
    Jun 2009
    Ecosse
    1,580
    Downloads
    18
    Uploads
    Quote Originally Posted by offsystem View Post
    .......of course it will be mate
    REMEMBER......PAIN..IS JUST WEAKNESS LEAVING THE BODY..
    YOU DO NOT WANT TO BE::SO READ THE RULES BEFORE POSTING
  21. The Following User Says Thank You to PremierD For This Useful Post:
