    Dec 2016
    Default TDS BMW remap question
    Basically i have some remap files for the E36 TDS 2.5 . Files with "MY ori" are both my ecu original reads.
    I don't have damos files for this but i had some remap files...
    But the thing is only one chip's versions matched, this has 2 chips for some reason (348) and when i compared with Titanium i saw increases. Could someone give me info on what chip does what or can take a look if i can just flash the modded files no problems?
    Both Mod and ori files are 001201.
    Mar 2017
    Could be one for the injector rotary pump maps and engine warm up maps, the other could be for turbo performance.
    I know on some petrol non turbo engines,one is a flash memory for storing adaptations and immo data and the other is for programming and map data.
    Do you know what chips they are?
    Dec 2016
    Hmm when i used titanium it identified both, the 348 had more maps but the 277 had only 1 map which was i think called injection phase or something.
    I think i'm only supposed to flash only the 348 anyway. It contained fueling maps, will try. EWS is stored in another chip which i will erase also since engine will be swapped.
    Mar 2017
    What are the chip's part numbers?
    Are they the same in terms of file size?
    Feb 2014
    Spain
    Hello
    348 has got torque limiter, duration, DW and smoke limiter.
    227 has got SOI maps and some kind of turbo limiter.
    Dec 2016
    Would it be okay if i only flashed modified 348 or do you think SOI map will limit too much?
    348 matches exactly and i viewed graphs had increases...
    I'm sorry the file is 277 . Full chip name : 2537355277.
