Sure how about posting the file
- Remember Don't Just Sit There In Boredom, Add to the Forum!!
sideshow (9th April, 2017)
hi neo
i just removed the chip and read it using my wellem as a 93c86 16 bit
here is the file does it look correct
just remember i have not swapped bytes as my wellem normally swap bytes on the 93c chips
can u please let em know if its a good read or i need to read it as something esle
bk 2016 np300 navara 29 maybe 93c86.rar
forgot to mention can u make it 5000 kms at moment that file is around 29 thou kms im not sure
Try it like this.
Kanesi algo ,Winai service ur file is bad ... qwerty3433 file good it has 4988 km and orginal file have 29776..
Nothing will remain in this World , Everything will come to END!
THINK POSITIVE NOTHING IS IMPOSSIBLE
Please do not spam by PM asking for help. Use forum, that is why we are here.
thanks boys good thing is the cluster didnt need to be pullled apart to much
chip is on back no needles to remove
just removed chip
did some research and its same algo as nissan note
rtbdiagnostic (29th October, 2019)
hi qwerty
the file worked fine
only thing i found was the key immobiliser light in the dash was on and after afew hours driving it went away
is this common
ระยะที่ถูกเก็บไว้ในบรรทัดถัดไป:
0060: xx xx xx xx xx xx xx xx 41 AE 83 5C 06 B9 0D 72
0070: xx xx 81 5C 02 B9 xx xx xx xx xx xx xx xx xx xx
นี่คือตำแหน่งหรือไม่
