Results 1 to 8 of 8
    Jan1980's Avatar
    Nov 2014
    Default Hyundai i30 key sync
    Hi mates.
    I swapped key electronic and transponder to a new key housing from my sister?s hyundai i30. I checked key on bench with frequency tester : 433 MHZ - fine. But the remote on the car does not work anymore. How can i sync the key to the car again ?
    THX
    Jan
    lion0304's Avatar
    Oct 2014
    If you have bad switch, remote wont work, even you can see frequency in tester. Change all switch to new, rework all solder joint
    It happen to me several time with Hyundai, Kia and others brands car.
    Kia, Hyundai no need sync or you can try reprogram only remote with X100 (no need pincode)
  3. The Following User Says Thank You to lion0304 For This Useful Post:
    Jan1980 (11th April, 2017)
    Jan1980's Avatar
    Nov 2014
    Now, remote works fine. But, i cannot start the car. I swapped transponder from old to new housing. It was not easy to remove transponder. I think, i damaged while removing. Which transponder i need ? How program key to first generation i30 ? I own AVDI and gambit.
    Aug 2015
    Mars
    can you read the immobilzer data?
    using AVDI can read, maybe your put too far coil cant detect your chip.
    IF I HELPED CLICK "THANKS"
    MVP pro,Tango, TMpro, SKP900, X100pro, i80pad, Mbtool, VVDI prog, KD900, Mini900, Ad900, Ts888, Ak500+, AK90, BMW Multitool, Xprog clone, miniprog, ETL, wellon vp380
    Jan1980's Avatar
    Nov 2014
    i did not read with AVDI. I have not a hyundai license. Key was in ignition lock, car did not start. I cannot read key in protag. I disassembled key again and tried to read transponder in protag, too. Without success. So, i think, transponder damaged while disassembling key the first time. I have seen, in protag (tagtool) software hyundai i30 is listed and i need pcf7936as transponder and i have to read eprom from ecu. Is this right ? Does it really works ?
    lion0304's Avatar
    Oct 2014
    Use blank PCF7936 direct programming.
    But you need pincode from VIN. X100, Fvdi can do easy over OBD.
    Jan1980's Avatar
    Nov 2014
    If i post VIN, can you give me pin ?? Can i do with AVDI without licence ?
    lion0304's Avatar
    Oct 2014
    I cannot give you pin from Vin, you need ask for someone else or buy online.
    I have no ADVI, so don't know. But FVDI full is clone from AVDI can do.
    Or go here: http://www.digital-kaos.co.uk/forums...r-free/page165
