bvm (27th December, 2019), masterskay62 (27th December, 2019)
Тhe codes are working.
Тhanks!
shooting (27th December, 2019)
Hello i have and me one blaupunkt and not know code now is on safe mode and not work put nothing .. what need make and who can help me with the code ?
vwz1z7e5558630
I search on book car and i find 1239 this will be code ? I find too late now is safe .. but i want know if this is the code
need to read the microcontroller.
https://www.digital-kaos.co.uk/forum...3&d=1448536976
sorry, my native language is Russian. the main thing is that you understand me. thanks
read.jpgi try but not work not know why but not work .. i make like this photo .. but not work read ..
everything is correct. it was supposed to happen ). It is necessary to apply 7.5 volts to the car radio. 12 volt only when entering the code.
Other microchips interfere with reading.
B.up Acc needs to be reduced to 7.5 volts. This condition is for VW Navigation only. Audi Navigation reads at 12 volts.
But the code is ok ? Can somebody verify ?vwz1z7e5558630
Leave it on for 1h it will clear SAFE so you can enter code that you found, or read FIS and post dump we will check code is it right
Hello everyone. Need code for VWZ1Z7 (3B0 035 191D). Dump attached. Thank you.
masterskay62 (13th June, 2020)
Hi.
I have VWZ1Z7 (1K0 035 198 B) and I've tried to read FIS using the method from this article.
As I know the 20, 40, 60 lines of a dump must be the same. But I had only about 1 second after pushing on the "on/off" button for reading and each time i've received different data. Also i've tried to lower the voltage to 7.5v. But in this way the mfd2 just has been switched off.
I've found some information and now I'm not sure about the right connection. Should I connect 5v instead of GND to the point 3?
