first dpf off use delphi or autocom and try change dpf ! after read flash and try dpf off !
Multiecuscan, kts 540 (license), autocom, delphi on the original files make a replacement for DPF and then regenerate (all for the manual), but the error does not go away .... There is a possibility to fix the flaw and a flush for
Multiecuscan, kts 540 (license), autocom, delphi on the original files make a replacement for DPF and then regenerate (all for the manual), but the error does not go away .... Maybe there is an opportunity to fix the eeprom and flash ...
2 weeks, more than 30 firmware ... Results-0
kinketotua (15th April, 2017), Patuk82 (14th April, 2017), stanislav georgiev (18th April, 2017), yildirimoto (3rd October, 2017)
Thanks. I'm writing the original eeprom and this file (flash) and no manipulations are needed?I ask about orig. eeprom ,because I noticed, on my firmware, that when the flash is changed flash and eeprom ....
Write flash file, eeprom should not be touched.
kinketotua (15th April, 2017), Patuk82 (15th April, 2017)
dobl? 1.3 mjet 75hp dpf off
solution tested
apreciated reputations and thanks
regards
doblodpfoff.rar
I know not with what weapons
World War III will be fought, but
World war IV will be fought whit
"sticks and stones"
I am afraid you will have to find a full bdm backup flash+eeprom from another ecu.
From what I see online that error remain in eeprom and won't go away even with correct dpf off file.
