Hi guys,
Does anybody know the eeprom location on this Honda ECU?
I did find an LR56 but there was no key data in there.
Cheers
Hi guys,
Cheers
No direct access to the eprom on this ecu its buried under the heat sink. So you need to read it from the back.
CaioW (5th October, 2017), cheaper (4th March, 2022), daxxer (18th April, 2017), DOUGLASDL (8th September, 2017), dune85872005 (18th April, 2017), eddierice (19th April, 2017), euasmdas121231 (29th July, 2020), Fallen (17th April, 2017), key4man (26th April, 2018), LKEY (7th September, 2017), p1et (7th September, 2017), Polkovnik1970 (27th March, 2023), TeL200 (24th February, 2023)
Hi Cromwe11,
Thanks for the info May I ask does this apply to the 2006 ST1300 with the 38770-MCS-G02 ECU as well? If so please may I ask for a photo graph further away to get location properly.
Please AND Thank You in advance.
Hi Cromwe11,
Please could you post a pic of complete box further away for locating purposes?
Please and Thank You
(Only been cleaning this ECU for about 2 hrs Ha ha)
Yes this is 38770-MCS-G02
Thank You very much Cromwe11 appreciate it have a great day further.
Thank you friend! Work perfect!
A rough But practical template for reference for next person to use for this ECU. And once Again Thanks to All for All Our Input.
Hi All
BIG thanks To ALL for All the INPUTS.
Hi. I have MCU honda st 1300 2007y. 38600-MCS-G01. Where is eprom.
6C7D57F3-7F40-4896-97B0-86C3F4BB69EC.jpg No12 in the image just behind the abs ecu that you have. You ECU will be 38770-MCS-G02.
TACHOSOFT will show you PART of the info...
lines 080 - 090 enter the info in KM
lines 0C0 - 0D0 enter same info in miles.
in my case I had to do both in order to have it working...
its a 93c56 eeprom
Good luck
byFritz (16th March, 2022)
Hi would this be the same location for the 8770-MCS-U71 Kelhn EP on a 2007 ST1300 also ?
大家好
請問,缺少C259零件,我該怎麼用呢?
謝謝你們
