Cut the wires on pins 24 and 28 on plug X60004 (40 Pin plug)
Brake lights will still work, but no brake signal to the ECU from the switch!
Hi Tuners
Im in a bit of a pickle. I have a bmw e46 ms43 ecu. What this vehicle does is intermittently it will not allow the car to have a throttle response due to the brake lights coming on. When u press brake and accelerate vehicle cannot accelerate. This happens when you drive as well. More often now it does not allow you to rev.
Is there anyone that can remove this function from ecu please. I have even tried another ecu and moved mapping over. I have tried a immo off too no luck at all. I think it has to do with cruise control but customer not worried about that
Please find attached orig file which is matched to ews. Dump from amd 29f400bb
Siemens MS 43 7511570
5WK09912 index 04
Thanks in advance
ascotauto (20th April, 2017)
ok did that cut wires no revving up at all. What i do see is i get 11 volts when i brake and 0 when i dont brake. Please note this is the 2nd ecu. Can this rev limiting not be removed from flash dump?
I think thats from your ASC or DTC. You only have to turn the system completely. Press and hold the ASC/DTC button for a long time until the Traction Control and the Stability Control lamp shine.
Thats it i think.
Sorry for my bad english.
ascotauto (21st April, 2017)
Using a DSC system (MK60) in my convertible with MS43 and i can easily break and revv match the engine ;-) No modification done. Thats with our ews-off files.
ascotauto (24th April, 2017)
ok do you have a off file with that function disabled as well? please post or send to me as im running out of time and have serious time and money invested in this vehicle
ascotauto (28th April, 2017)
ok bud appreciate the feedback car running fine 3days with a immo off and airflow unplugged not my exact repair method but its working and customer happy
hi all
my nightmare is back. Attached is the immo off file i used. i had another 6 cyl in today and i checked it can rev with foot on brake. It seems i have abs or dsc fault. @cloudforce the traction control trick didnt work. Is any one able to turn off the abs or dsc function in this dump? ive stripped car wiring ok everything tests fine. 3 Brake switches later 2 ecu and a airflow meter and its the same. Please help
admin please allow me to post rar file please
attach zip file instead?
still not allowed to post any sort of file
Admin could you assist in this regard please ?
