Would it help with a TAN code gen?
J?rgen
J?rgen
It seemes a TAN code gen did not help. I think I need a SCN-code.
I have a problem!
Some screen shots
First i identify the vehicle.
It is a Roadster, I choose System
In System I choose A1
In A1 I choose control unit adjustment
I choose Read variant coding of control module A1 (instrument cluster) and change if necessary.
This comes up!
I click F3 and this comes up
I will go on in the next post
I klick F2 or F1 and this comes up.
And it goes back to
What is the code I need?
It is hexa. (Meaning 0 to F instead of 0 to 9)
J?rgen
I have put the English image in stead of the Swedish.
Is there any kind of program that can be used to see what the program is waiting for here and then go in and change what it does when the right or wrong code is put in? If so You (I) could make any code fit!
Mate i have seeing this thread many times to different forums...
Why do you need this value,why do you want to do adaptation?
i have change many many times cluster in fortwo and roadsters, all works perfect....i cant get the point yet......i have never use adaptation at all ,any way u know better,
Smart car engineer ,
Well one thing is that I am sure that I can get the current fuel consumption on the speedo and an other thing is that I have converted the car to E85 (ethanol) and that is done either by prolonging the injectortimes or bigger injectors and then I need to adjust the setting to get the display to show the right value.
Hi J?rgen,
At least you have an actual problem to solve using your MB STAR - I have solved the one main issue I bought my one for :- Adjusting the clutch.
Are you sure the things you want o change are in the instrument cluster? Have you tried altering the fuel injectors and seeing it the instrument cluster automatically changes?
Just a thought.....
John
Nice to see You again John!
That is a good idea but I also wanted to show the momentary fuel consumption in the speedo.
I will take a look in the other parts of DAS to see if that part of the problem can be solved like that.
J?rgen
I have had a look around in the different parts of the DAS but not found anything to adjust the injectors. In >System>Adaptations>Read coding and change if nessesary there is only the choyce of what mode the gearchange is in when the ignition is put on.
J?rgen
