you can read it by opd but need special mb cables
I'm trying to read the firmware from the electronic engine management module TEMIC from the car MB ATEGO 816 4.2 2007. Inside the memory is 29F400. Reading is trying to do with the KESS programmer, both through OBD mode and via BOOT. In both cases, the ID can not be obtained. According to the KESS documentation for programming this unit, a special cable is required, I do not have such a cable. Can someone tell me how to connect correctly and read the firmware? Connection did according to the documentation that is in the attachment.
TEMIC_ISTRUCTION_CONNECTOR.pdf
licensed Winols user. original ECM titanium, Swiftec user etc...
I'm using FG tech and followed those instructions but can't get it to read boot mode did you manage to get a reading and how do I read the MB Atego Temic ecu in boot mode?
I do all over OBD with Kess Temic Cable
If you find my post helpful please hit Thanks button.
You can also hit Reputation button if you are kind enough.
