Results 1 to 5 of 5
    May 2012
    Default Astra G 2.0dti 2003 EGRoff PSG16
    Can someone help me with do EGR OFF in this ECU? PSG16
    I nead solution with disconnect valve.
    File read with MPPS 18.
    try this send result
    pass pm
  3. The Following User Says Thank You to nikka For This Useful Post:
    ars1 (23rd April, 2017)
    May 2012
    I am asking for a solution to the problem - t car still in limp mode (2800pm)
    pawelelectro's Avatar
    Jun 2011
    Tested.
    Close egr manually, disconnect plug.
    Correct checksum
    WinOLS (Opel Astra-G (EGR OFF) - ).zip
    Remember about thanks + rep.
  6. The Following User Says Thank You to pawelelectro For This Useful Post:
    May 2012
    thank you pawelelectro works fine - no limp mode, no dtc
