    Jul 2012
    Default ODIS V3.0.3 problem connection to VAS5054, help needed...
    I have installed ODIS V3.0.3 and run update with postsetup 9.3.10.
    Everything looks good, but the problem is that it can`t find the API so it dosen`t connect to the car.
    Have installed usb driver.
    Anyone have a soulution for this?
    Thanks,
    regards
    b
    Check drivers from this site:DPDUAPI.txt
    Jul 2012
    Thanks, is there anyone of them know to work?
    I have used v1.20.23 and the one installed with program v1.20.37. with this one I can get info on the VAS unit in odis with HW serial, but it is still no API loaded in system enviroment, so no connection to the car.
    Jul 2012
    After some investigation I have found that I need some files to folder: C:\ODIS-DIAG-MODULES\MCD-SERVER\VWMCD.
    Need from that folder; converter, MCD3D_PINS, MCD3D_PROJECTS, MCD3D_SERVER, TESTERID.
    Someone have these files for me?
    Jul 2012
    Have found the files and now I got it talking to the car, so thats all good.
    But when I log in to odis I get a box that want me to log in, also when I try to flash files I get a login box, so it is not possible to do flashing....
    Is this something wrong with my installation or?
    In ODIS S is hard to flash, better is ODIS E for flashing.
