Z22XE (Simtec71) with carprog on table - status % jumping
Results 1 to 3 of 3
    Feb 2017
    Downloads
    Uploads
    Default Z22XE (Simtec71) with carprog on table - status % jumping
    I'm trying to read the PIN of a Z22XE Ecu (Simtec71) with an original Carprog. When I choose Simtec 71 advanced it seems to try to read the ecu but the status percentage bar will only jump back and forth (between 0% and 98%) for about a minute before it shows that it could not connect to ecu.
    The Pinout I use is: 12+ for Pins 31,32 and 64 ; K-Line on Pin 5 and ground via ECU-box
    The strangest thing ist that THIS pinout works well with an original OP-COM which will be able to read the ECU this way...
    Any ideas?
    98
    Downloads
    252
    Uploads
    Verify your A1 adapter
    Sent from my V9H using Tapatalk
    Feb 2017
    Downloads
    Uploads
    It's a brandnew original A1 Multi - adapter...
