Results 1 to 15 of 15
    Jun 2016
    Default Cooling Fan Starting Temperature
    Please Help me to find the Cooling Fan Activation Temperature in ecu Bosch ME7.4.4.
    At current condition the low-speed fan start on 97 C and high-speed Fan start on 108 C and I want to change it.
    What is factor and offset of coolant temperature on this ecu?
    Dump is attached.
    Jun 2016
    Is there Damos for ECU Bosch ME7.4.4?
    Jun 2016
    please help
    bobolin4o's Avatar
    Apr 2010
    Bulgaria, V. Tarnovo
    Quote Originally Posted by likenoother View Post
    please help
    Have you tested my file?
    NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
    If your PM box is full, clean it right now...
    Otherwise, your requested file will be deleted... for ever!
  5. The Following User Says Thank You to bobolin4o For This Useful Post:
    likenoother (6th May, 2017)
  6. #5
    Jun 2016
    Yes I tested your file but not working unfortunately
  7. #6
    joker01's Avatar
    Jan 2018
    guys I should also change the intervention of the cooling fan ..... someone to a damos for m7.4.4 / me7.4.4 to share or exchange ???
    Thanks in advance
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
  8. #7
    bobolin4o's Avatar
    Apr 2010
    Post your file here...
    1. Which type of Fan you have? With stages, or is linear...
    2. At which temp. (coolant, through diag!) the Fan starts to spin at all and at which temp. the fan is at highest speed?
  9. The Following User Says Thank You to bobolin4o For This Useful Post:
    TPS (24th August, 2019)
  10. #8
    joker01's Avatar
    Jan 2018
    here is the file ......
    the fan should have 2 speeds and the 2nd part 97/98 °. this is what the mechanic I am doing is telling me.
    knowing that there is control on the map I wanted understand us a little more ....
  11. #9
    bobolin4o's Avatar
    Apr 2010
    Quote Originally Posted by joker01 View Post
    97/98 is not too high temp. for highest stage of the cooling fan, my own car starts at 102...
    Maybe you should clean/replace the radiator itself... cooling pump etc...
    Anyway, you can try this file...
  12. The Following User Says Thank You to bobolin4o For This Useful Post:
    joker01 (24th August, 2019)
  13. #10
    Meat-Head's Avatar
    Could you not have left organic system as was and added external temp thermostat from ebay
  14. #11
    joker01's Avatar
    Jan 2018
    yes I know that there are other solutions like external thermostats, switches etc ..... but I wanted to understand where the management was in the map .....
    thanks anyway ..... as soon as I have the machine available again I'll do a test .....
    with this file how many degrees did you anticipate ??
  15. #12
    bobolin4o's Avatar
    Apr 2010
    It is complicated, but... here is the map, which i think is responsible for the cooling fan actuation depp. from the engine temp.
  16. #13
    joker01's Avatar
    Jan 2018
    ok, you have mod i bp ..... at what address are the values in z???
  17. #14
    bobolin4o's Avatar
    Apr 2010
    Mate... this is BOSCH ECU....
    Think...
  18. The Following User Says Thank You to bobolin4o For This Useful Post:
  19. #15
    joker01's Avatar
    Jan 2018
    Ok ok.......thanks!!!!!
