Results 1 to 4 of 4
    May 2016
    Default egr off needed MB 220cdi edc16
    Hello i have E class w211 2001 year with 220 cdi engine, in city driving engine loss power and i need to restart the car to have power again on delphy tester have error code for egr valve i want to turn off egr if anyone can help me.
    mercedes w211 220cdi ori.rar
    thanks in advance
    Aug 2014
    you can try this
    but if it's stuck open mechanically you will have to put an egr blanking plate (always recommended)
  3. The Following User Says Thank You to lsdlsd88 For This Useful Post:
    Gator (3rd May, 2017)
    luca22's Avatar
    Dec 2010
    That is 100% EGR off closed solution without blanking plate. CHS calculated
    MB C egr off (+map) - NR363868).rar
    Luca
    PLEASE PUSH THE BUTTON THANKS IF MY WORK HAS HELPFULL
    AND REPUTATION BUTTON (starr)
  5. The Following User Says Thank You to luca22 For This Useful Post:
  6. #4
    May 2016
    Thanks for the help from you guys i will test probably tommorow and i will report for results, no its not stuck open it is not oppening when it should and ecu sees that and put my car into limp mode
