Results 1 to 10 of 10
    soxten's Avatar
    Mar 2013
    Default How to clone Volvo On Call module?
    I have a broken Volvo on call module here as I need to clone info to used.
    Volvo oem wirkshop cant program a used in to car.
    I have check pcb but cant find any Eeprom or mcu as i known....
    Any one as have made this before?
    Skickat fr?n min iPhone med Tapatalk
    soxten's Avatar
    Mar 2013
    I find a flash (BGA) as having number m29dw323dt
    soxten's Avatar
    Mar 2013
    any one as have done or have info about this unit?
    soxten's Avatar
    Mar 2013
    it looks like Segger J-link tool can read this mcu wit J-flash prog.
    But I dont know how to connect (pinout) from mcu and tool.
    Please need help here!
    Any one that can this tool/mcu and know this?
    Mcu on pcb is TFBGA48 modell.
    mcu has glu on it and a hell to remove safe....
    I have remove one and clean pcb to make pinout/connection on pcb.
    Here is pdf on mcu, and on page 8 you find pinout on mcu.
    https://www.micron.com/~/media/docum.../m29dw323d.pdf
    Here is info about pinout.
    Name Description Direction
    A0-A21 Address inputs Inputs
    CE# Chip enable Input
    OE# Output enable Input
    WE# Write enable Input
    RP# Reset/Block temporary unprotect Input
    RY/BY# Ready/Busy Input
    BYTE# Byte/Word organization select Input
    DQ0–DQ7 Data input/outputs I/O
    DQ8–DQ14 Data input/outputs I/O
    DQ15A-1 (or DQ15) Data input/output or address input (or data I/O) I/O
    VCC Supply voltage Supply voltage
    VPP/WP# Supply voltage for FAST PROGRAM (optional) or WRITE PROTECT command Supply voltage
    VSS Ground
    NC Not connected internally
    soxten's Avatar
    Mar 2013
    Need help on this case.
    Any as have some info how to read this mcu or unit?
    Mar 2016
    if you have dice i can help you coding spare module over team viewer.
    soxten's Avatar
    Mar 2013
    Quote Originally Posted by spokoluzik1 View Post
    Ok is it posible to install a used module with vida?
    Skickat från min iPhone med Tapatalk
    Mar 2016
    Yes. Just need to run reload. If you haven’t got acces to online Vida I can help you out.
  9. The Following 2 Users Say Thank You to spokoluzik1 For This Useful Post:
    hpsyndicate (15th March, 2018), soxten (9th March, 2018)
  10. #9
    Jul 2024
    Finland
    How was this resolved?
    I myself am changing the VOC / PHM module from the 2013 year model > to the 2014 year model. The new used module(facelift 2014 phm) is from a scrap yard and contains the data of the former car (probably in some eeprom) and they should be cleared to make the module "virgin". Any tips?
  11. #10
    Jul 2024
    Finland
    if this works, it may also be possible that the car's 3G PHM / VOC module could be upgraded to a facelift 4G module!! and that would be a big deal in these! ��
